It is currently Fri May 22, 2026 8:06 am
 Post subject: SB Chevy valves
PostPosted: Mon Mar 19, 2007 6:30 am
I seen awhile back were someone posted a topic about using valves out of a 305. Could someone give me some more info about this . What size are they? Are they a direct drop in or do you have to modify the valve or head etc?
PostPosted: Mon Mar 19, 2007 7:31 am
The Chevy valves will require custom work as will any oversized valve. I would recommend the SI big valves for the /6. That's what I used on Greg Mader's head. Valves that are larger than that are too big for the ports. I've seen flow numbers for some rather big Ford and Chevy valve /6 heads and they just don't flow any more than the SI valves. The SI valves are made for our engines, which means the machining work is minimal.
Greg's head:
http://powrehaus.com/2006/12/05/old-sla ... new-power/
SI Valves:
http://www.sivalves.com/ocdomestic_valvesps_dodge.html
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Mon Mar 19, 2007 7:33 am
You can use SBC valves in the 1.72/1.50 size. I have them in the Valaint. The valves I used have the same stem size as slant (3/8) but they are available in 5/16 as well. I used the Chev springs, retainers etc. You have to get the head machined to accept both the valves and the springs.
Caveat: the Chev valves are longer than the slants....some accomodation for this is necessary.
Is it worth it? absolutely!
Users browsing this forum: Ahrefs [Bot] and 14 guests
