int/exh flange mismatch
https://slantsix.org/forum/viewtopic.php?t=22329
Author:  flatiron [ Mon Mar 19, 2007 3:45 pm ]
Post subject:  int/exh flange mismatch
I'm in the process of match porting my head and I noticed quite a difference between my clifford intake flange .340 thick and my split dual exhaust manifold .515 thick. What do you do about this.Use a spacer on the exhaust
or shave the intake.
I also have a offy intake it measures .520 thick but I was told that a Offy is not as good as a Clifford but I don't have the Experince to say. So I could mount the Offy and the ex manifolds and the thickness is very close.
I also have a set of headers pt#5601H that measure .320 thick which is real close to the Clifford. But after reading Doc's and other articles I just as soon stay away from headers.
So I have many options to choose from. What would be the best combo for me? What would you do?
Author:  Doc [ Mon Mar 19, 2007 3:52 pm ]
The factory flange thickness is a little over 1/2 inch (.500)
Is your Clifford intake manifold new or used?
Author:  flatiron [ Mon Mar 19, 2007 3:57 pm ]
It is used
Author:  Doctor Dodge [ Mon Mar 19, 2007 7:04 pm ]
It is used
Sounds like someone surfaced it to get the manifold to match a thinner header flange.
Time to make some spacers.
