It is currently Tue Apr 28, 2026 5:13 am
PostPosted: Wed Mar 21, 2007 6:39 pm
I heard from some one that claimed to rebuild 225's that they made a three inline carb manifold for the 225 slant. is this true?
PostPosted: Wed Mar 21, 2007 6:59 pm
Triple side-draft Webers are not uncommon on a slant. It's not a "factory" option but it is doable.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Mar 21, 2007 7:00 pm
That would be a Weber side draft set-up. It was not a factory installed system.
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Wed Mar 21, 2007 8:21 pm
Triple Webers or triple SU's. I had three of the triple SU intakes; can't remember if I sold them all off or if I kept one. None of these was a factory item, all aftermarket, mostly from Australia.
PostPosted: Thu Mar 22, 2007 4:30 am
Dan,
I'm curious... did you ever get to run one of the triple SU intakes? They look pretty neat, and the simplicity of the SU carbs is intriguing.
-Mac
PostPosted: Thu Mar 22, 2007 2:25 pm
do you know were i can get a look at one on a site or maybe part numbers and is it a problematic bolt on that would be more hassel than what its worth?
PostPosted: Thu Mar 22, 2007 3:29 pm
Triple SU intake is available at this site:
http://www.pentastarparts.com.au/sunsho ... /subid/17/
Triple Weber Intake is available at this site:
http://www.cliffordperformance.net/
Keep in mind that the Australian dollar is not the same as the American dollar (US cost will be less), and that Clifford Performance is often difficult to get parts shipped from there once you have paid.
Problems with triple carb setups include complex linkage arrangements and keeping all three carbs in synchronous tune, although there are solutions for both. The question may become how much work you are willing to go through for performance. The triple intake is known to be a killer combination, but a lot of work for a non-race vehicle.
-Mac
PostPosted: Fri Mar 23, 2007 12:05 am
another problem is you have to have shop make you a header. I know because I grew up 10 minutes away from clifford and had spent some time with the man him self, 6=8, and he quoted " none of my headers will work the flanges are to wide for the intake"
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Fri Mar 23, 2007 1:19 am
Car Model: 69 Valiant 225, 70 with a 265, 70 with a 318
I have a triple Weber manfold for a slant, Lynx brand, appears to be new.
I have since bought a Hyper pak and dont require it.
250 Aussie dollars owns it if anybody is interested, but you can probably buy one there cheaper.
Richard (aka Fingers)
PostPosted: Fri Mar 23, 2007 9:27 am
Same ol' Clifford, full of laughs. :roll:
There are at least five different triple-carb intakes that've been made over the years for the slant-6, by different makers, and their designs (including flange width) aren't all the same. I've seen several of these triple intakes fit just fine with commercial headers, and dual Dutra Duals would work, too.
PostPosted: Fri Mar 23, 2007 10:56 am
Here is a pic of an inline Mopar engine in Australia with the webers.
http://arshowpics.fotopic.net/p28591676.html
Here is a link the GPRS guys sent me when I got their graphite gaskets for my Slant. Lots of cool Mopar models you don't see over here.
Go through these pics and I'm sure you will turn up a Slant with the webers.
PostPosted: Fri Mar 23, 2007 1:00 pm
Here's a picture of a slant with a triple SU setup:
PostPosted: Sat Mar 24, 2007 12:51 am
That's a Nissan motor.
PostPosted: Sat Mar 24, 2007 11:15 am
Oops :oops: . I haven't seen those 245 or 265 up close before and just assumed. Silly me.
