| Exit size for Exhaust Manifolds https://slantsix.org/forum/viewtopic.php?t=22362 |
| Author: | flatiron [ Thu Mar 22, 2007 5:12 am ] |
| Post subject: | Exit size for Exhaust Manifolds |
I'm in the process of making my own duels and I'm wondering how big the exit should be going from each half. The different things I've read says 1.625 40 inches long for headers. But I'm running 3 into 1 so should I go alittle larger say 1.75 or 2.0? |
| Author: | Doc [ Thu Mar 22, 2007 12:03 pm ] |
The outlet size on the factory manifold and on Dutra Duals is 2 inch. DD |
| Author: | stolan83 [ Fri Mar 23, 2007 12:09 am ] |
I have a set of the clifford duals if you tell me what you are looking for I will get the sepcs the best I can, they are off the car right now so it will be easy |
| Author: | 70valiant [ Fri Mar 23, 2007 4:00 am ] |
Clifford duals use 2.5" collectors. V8 headers usually use 3" collectors. |
