It is currently Thu Nov 19, 2026 10:21 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page 1 2 3 Next
PostPosted: Tue Feb 20, 2007 1:44 pm
Would the conversion of our engine to a D.I.S. require a distributor plug or other fabrication? What I'm trying to figure out is if anything will be damged by the removal of the distributor and simply putting a plug in its place. I've seen this done for VW's but I just don't know about slants.
The old white brick
PostPosted: Tue Feb 20, 2007 1:47 pm
All you should need is something to cover/plug up the hole.........
PostPosted: Tue Feb 20, 2007 3:38 pm
Tell us a little more about the kind of system you are considering using.
Sam
PostPosted: Tue Feb 20, 2007 3:53 pm
Thanks Ed, that's what I was hoping for. As for which system, I was strongly considering Ford's EDIS to handle the ignition.
The old white brick
PostPosted: Tue Feb 20, 2007 4:23 pm
what will you use for a trigger?
69 valiant
PostPosted: Tue Feb 20, 2007 6:23 pm
EDIS will require a 36-1 trigger on the crank pulley and a VR sensor. I'm planning to do this eventually and have gathered the EDIS module and an Interpid coil pack already. Just need to get the trigger wheel.
I don't see any problem with plugging the distributor hole. The distributor gear on a slant only drives the distributor.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Feb 20, 2007 6:29 pm
You can buy the ford trigger wheel new from napa. Easier then fussing with a puller at a junkyard. Think the ones I bought were less then $15.
Are you going to use MS or some other computer to drive the ford module?
PostPosted: Tue Feb 20, 2007 6:58 pm
I plan on eventually using MS to control Fuel and spark, I'll start with spark while i get the fuel side sorted, plumbed, etc...
The old white brick
PostPosted: Tue Feb 20, 2007 7:12 pm
What does the acronym EDIS stand for? Can you point us towards a web site or diagragm of how it works? How would you retrofit it to your slant? How many coils does it have? Is it a coil pack set up? I must say that most of the newer ignition systems are really unkown to me. I understand the old points and coil, the electronic ignition of Mopar style, and the Hall effect ignition, but all of these have a distributor that routes the spark to the proper plug through a rotating rotor and with a distributor cap. Can anyone enlighten me/us here. I am sure I am not the only one left in the dark.
Sam
PostPosted: Wed Feb 21, 2007 1:32 pm
Actually you'll probably get more info from google on this subject than from me. EDIS stands for Electronic Distributorless Ignition System. Found this. Hope that helps. It uses a coil pack and it triggered by a 36-1 wheel placed on the damper/crank pully, which triggers a VR sensor. You do need a computer to control it, like megasquirt, or you'll just get a 10 deg advance signal, which is the unit's Limp Home mode. to retrofit the slant, you'd need a coil pack, wires, an EDIS module, a spark management system to do your timing curve, and the related wiring harnesses. It lets you chuck the distributor, which is one less part that I know I can break.
The old white brick
PostPosted: Wed Feb 21, 2007 2:02 pm
As technical as your going to get...
http://www.bgsoflex.com/mjl/mjl_edis_summary.html
Howto for mating with MS - http://megasquirt.sourceforge.net/extra ... dware.html
PostPosted: Mon Mar 19, 2007 6:42 pm
the distributor gear on the cam also drives the oil pump, right? why did you choose the ford system? i had considered building a DIS using MSD parts. i was going have the flywheel indexed to the crank and have three magnets installed. i figure a hole could be made on the right side of the engine back there where a pick up could be mounted. i have been told that the further out the magnets can be placed the more accurate the timing can be. thoughts?
zedpapa
soon to have 5 gears!!!
PostPosted: Mon Mar 19, 2007 7:46 pm
I don't know truthfully, that's what the original intent of this thread was, but I seem to have been idealogically hijacked by a technical question. I chose the Ford system, becuase of price and availability, and available informational resources for set up. Truthfully, I know next to nothing about a flying magnet setup like you're considering. But yes, having a greater rotational distance between your magnets should allow for a higher accuracy of timing, that or use smaller magnets.
The old white brick
PostPosted: Tue Mar 20, 2007 7:44 am
All the DIS support from MegaSquirt is geared toward the Ford EDIS. That might be one reason.
Mike
Recognized by US Federal Courts as a Fuel Economy Expert!
PostPosted: Tue Mar 20, 2007 9:55 am
zedpapa
The cam distributor gear drives the oil pump - the gear on the distributor doesn't, unlike many V8s. The oil pump has a separate drive gear.
EDIS is pretty straightforward to get up and going, but Megasquirt-I (and soon, Megasquirt-II) can drive other DIS systems by operating the coils directly. You do need some means of identifying the cylinders, so a 3 tooth wheel will only work if you add some sort of second trigger to identify the cylinder.
A large diameter wheel can boost accuracy a bit, but once you get past a certain point it doesn't really help. Some systems such as EDIS and Megasquirt-II can gain more accuracy from a wheel with more teeth, too.
