Case Spreader
https://slantsix.org/forum/viewtopic.php?t=22555
Author:  dakight [ Tue Apr 03, 2007 9:44 am ]
Post subject:  Case Spreader
I have a 7.25 rear axle with LBP form a mid 70s A-body car. I also have a sure grip which I want to install in that housing along with a set of 3.23 gears. The FSM show a tool used to spread the case to facilitate removal and reinstalation of the carrier and ring gear but I don't happen to have one of these lying around. Is there an alternative method for performing this task?
Author:  sandy in BC [ Tue Apr 03, 2007 10:15 am ]
My 7.25 gear swaps had me prying the gears into the case with a big screw driver. It would take you longer to setup the spreader than it does to pry it in.
Author:  slantzilla [ Tue Apr 03, 2007 10:27 am ]
I had the same issues with a Dana 60. It took lots longer to do with a spreader. :shock:
Author:  dakight [ Tue Apr 03, 2007 11:06 am ]
Next question then. What do I need besides bearings and shims? Should I just buy a complete install kit?
Author:  slantzilla [ Tue Apr 03, 2007 9:52 pm ]
It's always best to have the complete kit. It may cost a little more, but it will save time in the long run. :shock:
Author:  dakight [ Wed Apr 04, 2007 5:03 am ]
I was afraid you were going to $ay that. <$igh>. Oh well, I'm not in this to save money. :roll:
