| Torqe Converter Too Big : ( https://slantsix.org/forum/viewtopic.php?t=22561 |
| Author: | maxxus [ Tue Apr 03, 2007 3:26 pm ] |
| Post subject: | Torqe Converter Too Big : ( |
The torque converter on my old transmission doesn't fit my new engine. The knob in the middle is about 1/8" too big and doesn't fit into the hole on the motor. The bell housing has the right bolt pattern to fit and I've used this transmission on 3 other 225 motors. The new motor I just ordered from Jasper. Do I need to get a new transmission? Can I just replace the torque converter? Would it be okay if I just grind a 1/16" off around the knob thats too big? Here are some pics: ![]()
| Author: | SlantSixDan [ Tue Apr 03, 2007 8:31 pm ] |
You are trying to put a '68-up transmission behind a '67-down slant-6 (or at least a '67-down crankshaft). This won't work for exactly the fit interference reason you describe. Options are: -Use a '68 or later crankshaft or engine assembly -Use a '67 or earlier transmission and torque converter -Swap a '67 or earlier torque converter, input shaft, front pump (and possibly other parts I cannot now recall) into the '68-up transmission -Machine the counterbore in the rear of the crank flange (maybe?). You cannot just install a '67-down torque converter onto the '68-up transmission (won't fit). |
| Author: | slantzilla [ Tue Apr 03, 2007 9:47 pm ] |
Call a converter company and get a late converter built with an early snout. Midwest, Edge, or Continental will do it for sure. |
| Author: | maxxus [ Wed Apr 04, 2007 7:22 pm ] |
Thanks for the info. |
| Author: | Charrlie_S [ Thu Apr 05, 2007 4:16 am ] |
Personal opinion: Did you order the engine from Jasper, as a particular year (68 or nrwer)? If yes, I would contact Jasper, and tell tem they sent the wrong year engine (67 or older), and they need to correct the problem. Jasper is a reputable company and their engines are not cheap. Why should you incur addition charges for their mistake? |
| Author: | maxxus [ Sat Apr 28, 2007 6:38 pm ] |
I called Jasper and told them what the deal was, and they admitted that they put the wrong crankshaft in. They did a return and repair and now the tranny fits. Thanks for the advice. |
| Author: | Charrlie_S [ Sun Apr 29, 2007 6:12 am ] |
Glad it worked out OK. Thanks for the update. |
