It is currently Sat Oct 24, 2026 10:48 pm
 Post subject: Timing Gear for Slant 6
PostPosted: Wed Apr 11, 2007 6:29 pm
Hi Guys.
I'm new to your forum. Does anyone know if there are timing gears available for a 225 slant 6 instead of a timing chain? I'm looking for the timing gear sound.
Thanks.
E-man
PostPosted: Wed Apr 11, 2007 9:10 pm
I've done some looking around (I have this insatiable curiosity) and I don't think so. There's no reason they couldn't be made but I don't think anyone is.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Apr 11, 2007 10:51 pm
There was talk of this Aussie vendor stocking them, I don't know if they ever did.
http://www.pentastarparts.com.au/work_in_progress.html
PostPosted: Thu Apr 12, 2007 5:27 am
I seem to remember that another engine (I'm thinking it's the big block Mopar) uses the same cam to crank spacing, so there's been reports of modifying a gear drive for that to fit a slant. Maybe Doc can shed some light on just which engine it is and what's required.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Apr 12, 2007 8:09 am
I wanted a gear drive something fierce.....until I did some research.
It seems they don't have the life of a good double-roller setup, they have a longer record for shedding teeth,(vs. chain) and they are real good at transmitting harmonics to the valve gear. So I went with a chain.....
That being said, if I had a "brand X" car, I'd probably have a gear drive. :wink: ,......it still has the cool facter.
I bet someone has researched this before......
Good luck!
BBBanjo
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Thu Apr 12, 2007 8:33 am
Seems like a staggering amount of effort and expense for no real benefit. There are much less costly and easier-to-install noisemakers available, if that's what you're after...
PostPosted: Thu Apr 12, 2007 11:41 am
I seem to remember that another engine (I'm thinking it's the big block Mopar) uses the same cam to crank spacing...
This is true but the top BB cam gear will need a special spacer to work on a SL6.
As noted above, there a better things to spend your time and $$ on.
PostPosted: Fri Apr 13, 2007 5:28 am
I had a '55 Chevy pickup that had a B&M straight cut gear drive and headers with Flowmaster 40 series mufflers. The cool factor wore off about 37 minutes after I bought the truck because I thought it sounded "cool". :roll:
PostPosted: Mon Apr 16, 2007 12:57 pm
Car Model: Valiant V200 225 4dr three on the tree
This one?
http://www.slantsix.org/galleries/lasve ... rdrive.jpg
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Mon Apr 16, 2007 1:26 pm
H'mmm...there's contradictory info on this box you've pictured. In marker it says "Slant 6", but in ballpoint pen (in the lower right corner) it says "Valiant 265", which refers not to the slant-6, but to the Australian-production Hemi-6. I'm not certain, but I'm pretty sure the two engines don't share a timing chain and sprockets in common.
PostPosted: Mon Apr 16, 2007 1:41 pm
Wait a minute, Dan...a Slant 6 and a Hemi 6 are the same thing...aren't they?? :wink:
I'm going to Slant hell for that one. :lol:
Bill
'60 Dodge Dart Pioneer
Vivian
PostPosted: Tue Apr 17, 2007 8:20 pm
In reality, the "Hemi 6" is neither a Slant nor a Hemi, but it is a 6. :lol:
PostPosted: Tue Apr 17, 2007 8:28 pm
Right...I was just rubbing Dan's fur the wrong way (on both points). :wink:
Bill
Vivian
PostPosted: Thu Apr 19, 2007 4:45 am
240 and 300 Ford is gear to gear from the factory, so is the air cooled VW.
My old '56 VW had a plastic cam gear. It failed at 35K '57 they went metal to metal.
What the hell were they thinking? :roll:
PostPosted: Thu Apr 19, 2007 8:12 pm
indestructable chevy straight 6's are also gear drive. ron
Users browsing this forum: No registered users and 16 guests
