| u-joints and wheel bearings..input please https://slantsix.org/forum/viewtopic.php?t=22570 |
| Author: | Slantin Forward [ Tue Apr 03, 2007 9:44 pm ] |
| Post subject: | u-joints and wheel bearings..input please |
hey guys..my car has been sitting due to bad u-joints or wheel bearings..not sure what the problem is yet..just alot of vibation on the highway and clicking sounds just driving down the street. my question is if its the wheel bearings..how much of a pain in the but is it replacing the rear wheel bearings? all input will be greatly appreciated.. thanks Dustin |
| Author: | slantzilla [ Tue Apr 03, 2007 9:51 pm ] |
If it is a 7-1/4 rear they are not too bad. Remove the brake drums and take off the 4 or 5 retainer nuts for the backing plates/axles. Pull the axles. Split the tretainers rings off with a hammer and cold chisel. Drive the old bearings off with a punch through the hole in the axle flange. Set the axle on a block of wood to protect the studs and drive the new bearing and retainer ring on with a long piece of pipe and a hammer. Install axles and brake drums. |
