| gauge questions https://slantsix.org/forum/viewtopic.php?t=22613 |
| Author: | Andy's GT [ Sat Apr 07, 2007 12:17 pm ] |
| Post subject: | gauge questions |
i just got a tach at an auction today and i just realized it doesnt have a knob to adjust between 4-6-8 cylinders, should it still work? its got four wires, two for the light and two others, one red and one green, where do these go? also got a three hole gauge panel, with an oil pressure gauge, engine temp gauge, and a ammeter, i can figure out the first two, but where do i wire the ammeter to? thanks guys! if it makes any difference, its a 67 dart gt supersixed 225 |
| Author: | 75 slanted swinger [ Sun Apr 08, 2007 6:03 am ] |
What brand tach is it? Some tachs have switches for 4-6- 8 cyl. Some have different color wires to cut or not cut for 4-6-8 cyl. If you go to someplace like Summit Racing and look up your particular tach you may find instalation instruction at the bottm of the page - usually in PDF format. You may also find the necessary info on the other gauges . Thanks Jeff |
| Author: | Andy's GT [ Sun Apr 08, 2007 7:27 am ] |
thanks, ill give it a shot! |
| Author: | Bren67Cuda904 [ Sun Apr 08, 2007 3:39 pm ] |
Remove the light bulb and there maybe some switches or wires behind it. |
