It is currently Sat May 16, 2026 12:57 pm
 Post subject: I am torn between ratios
PostPosted: Fri Mar 23, 2007 6:27 am
I can't decide between 3.21 or 3.55 gears for my 8 1/4. This car is NOT a daily driver but I would like to drive to the beach occationaly which is 1 hr of highway speeds at 70 MPH. Maybe 65 mph if I don't mind being past every 10 seconds. This car will never drive crosscountry. It'll likely only see the drag strip a few times. Is there a big seat of the pants difference between the two ratios?
PostPosted: Fri Mar 23, 2007 7:02 am
With your build I would be at 3.91 or 4.11.
With a Comp 264/9.25:1 I rarely get out of 3rd gear under 60 mph. I have to be doing at least 70 to even think about 5th.
To figure ratio: tire size, target rpm(at peak torque), cruising speed.
You also dont want to be below stall speed on the highway.
PostPosted: Fri Mar 23, 2007 7:12 am
What size are your tires? I had a 3.55 in my Barracuda with the A904 after having a 3.23 for many years and I could never get used to the revs on the highway. I was running 205/65-15 tires. If you will be running a taller tire then it won't be so bad. The other problem was that it ran out of Torqueflite's second gear too soon which doesn't give you a good passing gear in the 60-70 mph range. I think Slants like to pull taller gearing to make better use of their low rpm torque peak.
"Former Owner" of '65 Barracuda, 225, Auto, MP 2bbl intake, MP cam, Dutra Duals. Presently Moparless.
PostPosted: Fri Mar 23, 2007 9:20 am
I'am going to be running 26" tires. I am going with a 2500 stall convertor. I found one that will get me by until I upgrade to the more common trans and convertor. I think the 3.55 gear is best for my plans. Not the best power but maybe the best for my plans.
PostPosted: Fri Mar 23, 2007 9:46 am
Here is a link that may help you decide.
http://www.moparts.com/Tech/tech/img/AUTOMATICchart.xls
1971 D100 SWB Step side, 225, 3 on the tree, 3.91 gear
PostPosted: Fri Mar 23, 2007 2:55 pm
Car Model: 1962 Lancer 770
B. this is the calculator you want to use
http://users.erols.com/dmapes/CALCMENU.HTM
PostPosted: Sat Apr 07, 2007 5:05 pm
Car Model: 1964 Dart GT
With 26" tires, I would go with 3.55:1 More fun around town and at the strip but not too bad on the highway.
