It is currently Tue May 26, 2026 4:59 pm
PostPosted: Thu Apr 12, 2007 6:10 am
I found some where a chart showing the different length shafts needed between 7.25- 8.25-8.75 rears. I can't relocate it now. Where is this cart or what must be subtracted from the shaft to move from a 7.25 rear to 8.25?
PostPosted: Thu Apr 12, 2007 10:17 am
Do you have the rears? Just measure from the centerline of the axle to the center of the U-joint pocket in the yoke on both rears, there is your difference. I myself would prefer to measure for the drive shaft length while the rear is in the car, just to idiotproof things.
Excuse me, does this smell like chloroform to you?
PostPosted: Thu Apr 12, 2007 11:10 am
For the record
diff measurments
7 1/4 = 10 1/2"
8 1/4 = 11 3/8"
difference 7/8" longer. driveshaft to be shortend 7/8"
Measurement from 8 1/4 pinnon to trans tail including rubber dust boot is 53 1/8" this is with weight on the rear. Without weight on the rear its 52 1/2. So you can see that the driveshaft moves forward 5/8" when the car is raised.
Driveline place says its 1" difference according to the measurement from trans to pinnon that I provided. I can live with that.
