| header and intake ???? https://slantsix.org/forum/viewtopic.php?t=22627 |
| Author: | 1974duster [ Sun Apr 08, 2007 5:50 pm ] |
| Post subject: | header and intake ???? |
i was wondering what headers and intake that i should go with my 74 duster i want to get somemore power out of in i think about getting a 4 bbl on it but i am not sure what ones are the best |
| Author: | Doctor Dodge [ Sun Apr 08, 2007 7:52 pm ] |
For the street, you can't beat a Super Six and Dutra Duals. Far a race engine, use a Clifford intake and their shorty headers. DD |
| Author: | Ron Parker [ Mon Apr 09, 2007 6:23 pm ] |
Yep thats the deal Dutra Duals for the street . Aint so sure tube headers are any better at the strip. Thanks Ron Parker Bagels Juiced Im Bamboozled |
| Author: | slantzilla [ Mon Apr 09, 2007 7:28 pm ] |
We will soon see how much difference there is between headers and Dutra Duals. I have a pair of the cast manifolds to put in the Piggie until Harold gets my Cliffords and step tubes to me. |
| Author: | Doctor Dodge [ Mon Apr 09, 2007 9:50 pm ] |
My road toad Lancer does low 13's thru cast iron manifolds. DD
| Author: | 1974duster [ Sun Apr 29, 2007 8:21 pm ] |
i am going with a offy 4 bll and Dutra Duals for headers |
| Author: | Jeb [ Sun Apr 29, 2007 8:29 pm ] |
Quote: i am going with a offy 4 bll and Dutra Duals for headers
You slapping these on a stock engine or you doing a complete buildup? If it's stock I would STRONGLY recommend the Dutra Duals and a Super Six.
| Author: | saskatchewan [ Tue May 01, 2007 8:55 pm ] |
Hey I run a Offenhauser intake with Dutra Duals with a mild cam and it works great!! I spent enough time fighting with old Carter 2bbls and am much happier with the Holley 390. |
| Author: | Jeb [ Wed May 02, 2007 7:05 am ] |
Quote: Hey
You must have found some lemon Carters, because the Carter BBD is one of the most reliable carbs ever made.
| Author: | Mister Twister [ Thu May 03, 2007 7:43 am ] |
2bbl Thay were good back in the day. The last three we recived 1 was bad, it did not like to be wide open,got a bad flutter. Going to Holley on my set up! Hope this helps someone. Don |
| Author: | slantzilla [ Thu May 03, 2007 8:54 pm ] |
Quote: You must have found some lemon Carters, because the Carter BBD is one of the most reliable carbs ever made.
The problem is that many of the ones left have the throttle shaft bushings worn out, leading to a host of issues. Unfortunately, rebuilders don't do the throttle shafts and the rebuilts have the exact same issues. I ran a BBD on my Duster for a while that I had gotten the throttle shaft done on. It did work very well. |
