It is currently Wed May 06, 2026 11:50 pm
PostPosted: Wed Jul 04, 2018 5:39 pm
Car Model: 1967 Dodge Dart GT 225 Slant Six
Wanted to get a little piece of mind before traveling from Nashville, TN to Columbus, OH for this weekend’s Goodguys nationals. I had the engine idling in the driveway checking the transmission fluid and noticed the engine temp sitting almost at 210. I’ve got a 22” aluminum radiator (brand new), a 180 degree stat, 16lb cap, and running the 7 blade mechanical fan. I know there is no air movement due to sitting in neutral with the emergency brake on but with the engine not having a load on it I was a little concerned. Also noticed coolant dripping out from the drain line on my aluminum overflow bottle. Wanted to get feedback before making the 5 hour journey through the mountains on what they are calling for another 100 degree day.
Current Project: 1967 Dodge Dart GT, 2dr Hardtop California Car with 225 Super Six, Automatic 904 Transmission, and Factory A/C
PostPosted: Thu Jul 05, 2018 7:35 am
Do you have a shroud on the radiator? If not the fan will not do much.
I would take the car on a short highway drive, monitor engine coolant temps to
get more data.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
