It is currently Mon May 18, 2026 8:24 pm
 Post subject: In gear, outta gear
PostPosted: Thu Apr 12, 2007 10:25 am
my 904 has been actin weird lately...when i drop it down into drive it takes off normally...drops out of gear and then cathes really hard and goes again..and then later just for a split second it will do it again...any ideas :?:
PostPosted: Thu Apr 12, 2007 10:55 am
Not good. How long has it been, do you know, since the fluid & filter were changed and the bands adjusted?
PostPosted: Thu Apr 12, 2007 11:37 am
It sounds like it is low on fluid or "sucking air" past a loose filter.
