It is currently Tue Nov 17, 2026 5:26 am
 Post subject: Valve size
PostPosted: Mon Apr 23, 2007 11:27 pm
Will my 1.77 intake and 1.44 exghaust valves work on ahead with .50 shaved off it? Will it hit my stock pistions?
PostPosted: Tue Apr 24, 2007 4:40 am
It depends on how much camshaft you are using. :shock:
Unless you are using a real monster, you should have plenty of clearance. :D
 Post subject: vavle size
PostPosted: Tue Apr 24, 2007 6:28 am
i had a 540lift/ 255deg 0.050 with 1.80 intake/1.60ex valve, 0.080 off the head and .140 off the block,the valve to piston(stock0.060oversize) clearance of 0.065 int and 0.070 ex.
 Post subject: Thanks
PostPosted: Tue Apr 24, 2007 7:49 am
My cam is only .435 so it will work thanks for the info.
 Post subject: valve size
PostPosted: Tue Apr 24, 2007 9:48 am
you are good to go and good luck :D
