| Do 904's and 727's use the same dipstick? https://slantsix.org/forum/viewtopic.php?t=22747 |
| Author: | rock [ Mon Apr 16, 2007 6:30 pm ] |
| Post subject: | Do 904's and 727's use the same dipstick? |
Is the dipstick for the 904 the same one as for a 727? ( For trannies after '66) Thanks, rock |
| Author: | Doc [ Tue Apr 17, 2007 9:53 am ] |
Yes... and no. The dipsticks will fit in the same hole and use the same o-ring but lenghts and shapes differ based on trans type and the chassis they are used in. The biggest problem I run into is the location of the dipstick's bolt hole tab, those never seem to line-up to the matching bolt hole. These days... I simply cut and weld the tab into the needed position. DD |
