| New wheels/electric fans https://slantsix.org/forum/viewtopic.php?t=22775 |
| Author: | Bren67Cuda904 [ Wed Apr 18, 2007 11:15 am ] |
| Post subject: | New wheels/electric fans |
I finally have the new wheels on it all the way around. Got the fans installed and hooked to a Spal FAN-PWM controller. No noisey fans here. (unless I turn on the A/C) Got the 8 1/4 A-body rear installed, kindof. Still missing the driverside spring plate. I made a plate to temporarly hold the rear but it has no shock mounting point and is not very strong. Strong enough to drive a 1 mile to the tire shop where the measured for rear wheels and tires. Rears are Torque Thrust IIs 8"wide 4.5 backspacing and running 235-60-15 TA Radials. Fronts same wheel but 6"wide 3.25 backspacing running 215-60-15. Front has the MP Brakes disc conversion. Rear is 10" drums. In a couple weeks the motor should be done. http://www.renaissanceracing.com/Albums ... 7Side.html http://www.renaissanceracing.com/Albums ... opFan.html http://www.renaissanceracing.com/Albums ... deFan.html |
| Author: | slantvaliant [ Wed Apr 18, 2007 2:10 pm ] |
Pretty, pretty, pretty! Love the BIG valve in the engine pics. |
| Author: | sandy in BC [ Wed Apr 18, 2007 2:12 pm ] |
Thats a good look! |
| Author: | Dart270 [ Thu Apr 19, 2007 7:43 am ] |
VERY nice work. You should be proud of that rod... Lou |
| Author: | Bren67Cuda904 [ Fri Apr 20, 2007 10:26 am ] |
Thankyou for your complimants. I am a little confused about my feelings in regard to this car. I have never had a car that is done. This car should be done in the next month with the motor change. Then what to do with myself. I have been thinking about this car for a long time and when it done I think I am going to be sad. Its not how I thought I would feel when its finished. Some would say its never finished, but I really think it will be. I don't want to start other project, they just cost to much. I think I should call the white coats and have them drag me away for evaluation. |
| Author: | ROADRUNNER7169 [ Fri Apr 20, 2007 10:57 am ] |
its kinda like the empty nest syndrome |
| Author: | icaneat50eggs [ Fri Apr 20, 2007 10:58 am ] |
I wish I was" that" kind of sad! |
| Author: | Charrlie_S [ Fri Apr 20, 2007 11:05 am ] |
Quote: Then what to do with myself.
Bring it up to Valdosta, on Memorial Day weekend. You can race with the slants, or just show it off.
| Author: | heckshemi [ Fri Apr 20, 2007 11:20 am ] |
Bren, don't worry. It's never "done" |
| Author: | Bren67Cuda904 [ Fri Apr 20, 2007 3:05 pm ] |
Quote: Quote: Then what to do with myself.
Bring it up to Valdosta, on Memorial Day weekend. You can race with the slants, or just show it off. |
| Author: | 64 Convert [ Fri Apr 20, 2007 4:32 pm ] |
Glad to see that the double fan clears the water pump pulley. My Valiant will get hot idling in traffic with the aftermarket A/C running, so I've been wanting to see if two smaller electric fans will clear. What brand and size are they? |
