| Compression test numbers https://slantsix.org/forum/viewtopic.php?t=22799 |
| Author: | Jopapa [ Thu Apr 19, 2007 6:59 pm ] |
| Post subject: | Compression test numbers |
While I had everything apart the other day I did a compression test, and here are my results: Dry test; 125 130 130 130 140 135 Wet test; 125 135 145 140 155 135 This was with the engine still somewhat warm, but it had been shut off for about an hour before I got around to doing the test. Overall I think it's doing okay, save for the #1 cylinder. How does this compare to what some of you guys are getting? |
| Author: | SlantSixDan [ Fri Apr 20, 2007 12:55 pm ] |
These numbers say "Nothing to worry about" to me. Did you do the test with all six spark plugs removed, and the choke and throttle blocked fully open? |
| Author: | Jopapa [ Fri Apr 20, 2007 1:27 pm ] |
Quote: These numbers say "Nothing to worry about" to me. Did you do the test with all six spark plugs removed, and the choke and throttle blocked fully open?
Yes indeedy.
