Slant Six Forum https://slantsix.org/forum/ |
slant 6 noise https://slantsix.org/forum/viewtopic.php?t=22823 |
Author: | 1970valiantslant6 [ Sat Apr 21, 2007 5:41 pm ] |
Post subject: | slant 6 noise |
hi, this is a vague and i'm guessing repeated or stupid question, i'm new to this i have had my 1970 valiant since november and its making a really loud noise out of the exhaust manifold. i'm asking because it is comin from the 4th or 5 cylinder, i've forgotten which at the moment. but i know there is a rod goin from in the manifold to the carburetor. is it common, i've just ordered a manual so i've got nothing in terms of part names to describe what i'm looking for. thank you and pardon my lack of terms or vague ?'s my great grandpa gave me the car i drove it from eugene oregon back to sacramento and i love everything about this car. it runs a bit sluggish and i'd like to get her runnin like a champ again. thank you all!! ps how to i post a picture? |
Author: | wicked/six [ Sat Apr 21, 2007 7:36 pm ] |
Post subject: | |
sounds like you have an intake/exaust manifold leak. the rod most likely is the kick down linkage if you have an automatic trans |
Author: | slantvaliant [ Sat Apr 21, 2007 7:40 pm ] |
Post subject: | |
Welcome aboard! Read, search, ask, and participate, and you'll have your car running just fine. The Articles and Search are your friends! A loud noise from the exhaust manifold ... The rod you describe sounds like the choke linkage. The choke pocket is right over #4 exhaust. Possibly an exhaust leak, either from between the gaskets and head, or the gasket between the intake and exhaust manifolds. See if you can isolate it a little closer. Either way, it's not hard to repair. See Manifold Installation Instructions See How To Add Photos We'd love to see photos and details of your car, and it's a good idea to document your progress. Enjoy! |
Author: | wicked/six [ Sat Apr 21, 2007 7:58 pm ] |
Post subject: | |
my bad there is also a choke linkage that comes off the exaust |
Author: | 1970valiantslant6 [ Sat Apr 21, 2007 8:02 pm ] |
Post subject: | |
thanks guys. ah, so its a choke. is it suppost to be loose. i can wiggle it back and forth with no effort. |
Author: | HyperValiant [ Sat Apr 21, 2007 8:16 pm ] |
Post subject: | |
It very possibly could be a cracked exuast manifold as they are are common on Slants.My daughter and I swapped out the manifolds on her 72 Valiant today because the heat damper was froze shut,after we got the exaust manifold off is when we discovered that it was cracked right below the choke pocket. HyperValiant |
Author: | 1970valiantslant6 [ Sat Apr 21, 2007 8:31 pm ] |
Post subject: | |
ooooh. not good to hear but nice to know. i'll definatly be removing the manifold then. i've seen other intakes, is there anything worth replacing it with since it needs to come off anyway, same question bout the exhaust manifold. anyone make a header for these models? very much appreciate all the help. thank you guys. i tryed to link my photo, but it didnt work so here is a link. its a bad cell phone picture. but its my car and you can barely see my boy in the car. HE LOVES my car. http://www2.snapfish.com/slideshow/Albu ... _=93106111 |
Author: | wicked/six [ Sat Apr 21, 2007 8:56 pm ] |
Post subject: | |
http://www.putfile.com/pic.php?img=4079700 This is the header i had on my old engine. Headers are available just depends on what you want. |
Author: | 1970valiantslant6 [ Sat Apr 21, 2007 9:46 pm ] |
Post subject: | |
well, i'm not sure what i want. would be nice to have something that works what ever it is. the noise is so loud now i have to do something. where do you get manifolds or headers from. are the old manifolds worth getting welded. |
Author: | slantvaliant [ Sat Apr 21, 2007 11:12 pm ] |
Post subject: | |
New exhaust manifolds are available, as are junkyard parts. There are a couple of variations in the choke pocket, and cracks are common in older castings. Headers are available. Expect to do some fitting. A better alternative for many is the Dutra Dual - essentially a split cast exhaust manifold. Do a search, and read the article. This setup gives up little to headers in performance, can be quieter, and lasts longer. |
Author: | Davey [ Sun Apr 22, 2007 5:24 am ] |
Post subject: | |
I work at NAPA and did work for Carquest for a long time. I KNOW that NAPA lists new manifolds for slants, and I think Carquest may too. If you want to go back with new originals, they can be gotten easily. Davey |
Author: | 1970valiantslant6 [ Sun Apr 22, 2007 8:52 am ] |
Post subject: | |
thanks again. i checked out the dutra dual's. and ebay. i want to go to a wrecking yard today, is there anything specific that i should look for on the wrecking/junk yard parts. sacramento has TON of wrecking yards around here. also saw the super six intake and exhaust. that looks nice. just looked at napa and the stock exhaust manifold's are expensive. i think i'm gonna look for a good super six intake and carb rebuild it(if it needs it). exhaust. i'm gonna look around and see what i can find before i make a certain decision. you guys sure are helpful. |
Author: | Rust collector [ Sun Apr 22, 2007 9:50 am ] |
Post subject: | |
If you get a 2bbl setup, be sure you get all of it! Like the kickdown linkage, including the little arm on the transmission. At least if you have an automatic transmission. Oh, get it anyway, people are always looking for that linkage stuff. Uh, I might be off by a few years, but was there not a year or two that had a hole in the exhaust manifold, under the choke? I think it used a thin metal gasket-ish thingie to seal the hole? Just an idea? |
Author: | 1970valiantslant6 [ Sun Apr 22, 2007 9:58 am ] |
Post subject: | |
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &rd=1&rd=1 i was checking out this auction. also was looking at getting an electronic distributor. or a conversion kit. but i'm after the intake/exhaust first. i've started calling wrecking yards and not many have older mopar stuff. |
Author: | RDJ [ Sun Apr 22, 2007 5:09 pm ] |
Post subject: | |
You can get a relatively inexpensive chinese made exhaust manifold from 1Aauto.com ($130? shipped). I had one for the last year with no problems, but just went to the Dutra duals. As far as the manifold with the open choke pocket, I think it is the 70-72? years. That is what I ended up with (NOS) to do the rear half of the Duals. Since I had to cut/weld a plate for the split process, I just welded a plate over the choke pocket. I also got one of the exhaust/manifold gaskets from the Aussie guys at GPRS see this thread on the "hotbox" gaskets http://www.slantsix.org/forum/viewtopic.php?t=21864 They seal better and are great guys to deal with, no problems with international shipping. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
