| Pilot Bushing Removal https://slantsix.org/forum/viewtopic.php?t=2285 |
| Author: | Adam [ Wed Jun 13, 2001 11:45 pm ] |
| Post subject: | Pilot Bushing Removal |
I am putting a new clutch in my 80 Aspen Wagon and I figured while I had everything apart I'd put a new pilot bushing in the crank. My problem is that the only inside puller I can find locally which is small enough comes in a $150 (and low quality "Made in China" to boot) slide hammer set. One parts store employee suggested splitting the old bushing with a cold chisel, but I really don't think that's a good idea is it? Are there any alternate methods to removing this bushing or do I have to locate a small inside jaw type puller? |
| Author: | Charlie Schmid [ Thu Jun 14, 2001 1:38 am ] |
| Post subject: | Re: Pilot Bushing Removal |
: I am putting a new clutch in my 80 Aspen Wagon : and I figured while I had everything apart : I'd put a new pilot bushing in the crank. My : problem is that the only inside puller I can : find locally which is small enough comes in : a $150 (and low quality "Made in : China" to boot) slide hammer set. One : parts store employee suggested splitting the : old bushing with a cold chisel, but I really : don't think that's a good idea is it? Are : there any alternate methods to removing this : bushing or do I have to locate a small : inside jaw type puller? Pack the end of the crank with grease, Then install a rod that just fits inside the pilot bearing, and smack the rod with a hammer. The rod displaces the grease and pushes the pilot bearing out. Charlie flturbo6@aol.com |
