| Valve size https://slantsix.org/forum/viewtopic.php?t=22860 |
| Author: | WILL'S74 [ Mon Apr 23, 2007 11:27 pm ] |
| Post subject: | Valve size |
Will my 1.77 intake and 1.44 exghaust valves work on ahead with .50 shaved off it? Will it hit my stock pistions? |
| Author: | slantzilla [ Tue Apr 24, 2007 4:40 am ] |
It depends on how much camshaft you are using. Unless you are using a real monster, you should have plenty of clearance. |
| Author: | terrylittlejohn [ Tue Apr 24, 2007 6:28 am ] |
| Post subject: | vavle size |
i had a 540lift/ 255deg 0.050 with 1.80 intake/1.60ex valve, 0.080 off the head and .140 off the block,the valve to piston(stock0.060oversize) clearance of 0.065 int and 0.070 ex. |
| Author: | WILL'S74 [ Tue Apr 24, 2007 7:49 am ] |
| Post subject: | Thanks |
My cam is only .435 so it will work thanks for the info. |
| Author: | terrylittlejohn [ Tue Apr 24, 2007 9:48 am ] |
| Post subject: | valve size |
you are good to go and good luck |
