| Dizzy gear https://slantsix.org/forum/viewtopic.php?t=22861 |
| Author: | Burla [ Tue Apr 24, 2007 12:56 am ] |
| Post subject: | Dizzy gear |
Hey all I tried staring my 68 Valiant the other day only to find it backfiring and coughing. I went through everything I could think of till I found that the distributor gear was missing teeth. Ive replaced the gear but I need to where the rotor button is supposed to be in relation to the stroke? Any help would be much appreciated |
| Author: | SlantSixDan [ Tue Apr 24, 2007 6:46 am ] |
The rotor should point to about the 4:00 position when the frontmost cylinder is at the top (TDC) of its compression stroke. |
| Author: | slantfin [ Tue Apr 24, 2007 8:12 am ] |
| Post subject: | wondering same thing |
Somewhere I heard that the rotor is supposed to 'point at' the #1 cylinder at TDC. Is that for V-8's? It sounds like with the /6 you want the rotor to 'point away' from #6 cylinder? |
| Author: | SlantSixDan [ Tue Apr 24, 2007 8:16 am ] |
| Post subject: | Re: wondering same thing |
Quote: Somewhere I heard that the rotor is supposed to 'point at' the #1 cylinder at TDC.
Nope.Quote: It sounds like with the /6 you want the rotor to 'point away' from #6 cylinder?
You want the rotor to point to about 4:00 clock position as you look down at the distributor while you're standing at the RH fender of the vehicle.
| Author: | Doc [ Tue Apr 24, 2007 8:25 am ] |
The "rotor points to #1" is for small block Mopar V8s. For the SL6, pointed to the 4:00 position as SSDan noted. DD |
| Author: | slantfin [ Tue Apr 24, 2007 8:30 am ] |
| Post subject: | 4 O'clock: Clear |
Thanks, you guys are the most. |
| Author: | Burla [ Tue Apr 24, 2007 5:17 pm ] |
Thanks all |
| Author: | slantzilla [ Tue Apr 24, 2007 5:24 pm ] |
It depends on how the cap was wired and how the distributor was installed last time. If you point it at 4:00 and the #1 wire is at 12:00, you got prolems. |
| Author: | Bren67Cuda904 [ Tue Apr 24, 2007 5:38 pm ] |
Amen |
