It is currently Sat Nov 28, 2026 3:54 pm
 Post subject: SpeedO adjustment
PostPosted: Mon Apr 30, 2007 4:31 pm
In my 81 D150 my speed "O" is 5 mph shy of where it should be. I dont have huge tires on (195 15's) and I would like to adjust it so that it is closer to being correct (spot on would be nice).
Any info on adjusting it?
Superman
1981 D150
"The Khaki Machine"
PostPosted: Mon Apr 30, 2007 4:36 pm
They can't be adjusted, per se. If yours is reading consistently low, then a speedometer drive pinion with fewer teeth should be installed.
