It is currently Wed Nov 18, 2026 12:58 am
 Post subject: Great BBD Thread!
PostPosted: Fri May 04, 2007 8:59 pm
Moparts has a great one going in the Q&A section right now!
I am too lazy to type the addy here....................
PostPosted: Sat May 05, 2007 2:43 am
this is the link if anyone had problems finding it.
http://board.moparts.org/ubbthreads/sho ... ost3476696
PostPosted: Sat May 05, 2007 9:35 am
Looks to me as if the guy who started the thread doesn't have the knowledge or tools to diagnose the rather poorly designed emissions system (with O2 sensor and MCS-equipped carburetor) in his '86 Ram, so he's babbling about what a piece of junk the Carter BBD is.
I mean, c'mon, how seriously can a thread be taken that contains this statement (emphasis added):
BBD's are lousey carbs. They work great when new, but when they get to needing a rebuild, they should just be thrown away. Even the better parts store's re-man'd ones don't work right.
Well, yeah, duh, because there's no such a thing as "better remanufactured" carburetors!
PostPosted: Sat May 05, 2007 11:32 am
I agree Dan.
PostPosted: Sun May 06, 2007 7:05 pm
Moron, it is probably one of those crappy Holley 6280's and he thinks it is a carter.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sun May 06, 2007 8:19 pm
Dude claims to be a 20-year ASE-certified tech. If he's not lying, that says more about the low standards of the ASE certification process than about this guy's knowledge. But he's probably just lying. 2-year ASE techs shouldn't ask questions like "I'm sure it's not the heat crossover, but could it be the heat riser?" and "The heated air door, that's in the air cleaner, right?", and "Could it be a problem with the computer?"...let alone a 20-year ASE tech! :shock:
PostPosted: Sun May 06, 2007 8:30 pm
Dude claims to be a 20-year ASE-certified tech. If he's not lying, that says more about the low standards of the ASE certification process than about this guy's knowledge. :
Just a tick off topic. ASE certification is a joke.I was a ASE master auto tech, untill I let all of them expire. All it means is you know how to pass a test. When I got my last cert, for master, it was on auto transmissions. I have only worked on Powerglides, and 904/727 torqueflytes. Never worked on a electronic trans, but got 100 on the test. So now I am competent to do diagnostic and repair on a MB 6 speed auto. Yeah, right.
PostPosted: Sun May 06, 2007 9:29 pm
Probably more competent than those that work on them...........
:wink:
