It is currently Sun Nov 15, 2026 3:09 pm
 Post subject: Manifold vacuum stem
PostPosted: Mon Apr 30, 2007 2:48 pm
Is there an actual name for the manifold vacuum stem? My 2bbl intake manifold has that port plugged off, and I would like to get a stem for it. Is there a place that sells them new?
I have a new Holley 350cfm 7448 from Jegs. The only vacuum port on it is for the distributor vacuum advance (besides the PCV port) so it looks like I need a stem on the manifold to run my vacuum gauge off of. Is this correct?
PostPosted: Mon Apr 30, 2007 4:16 pm
vacuum tap (if it has one nipple), vacuum tree (if it has multiple). All you need is a brass fitting of the correct pipe thread on one end, and a hose nipple of the correct diameter on the other. Weatherhead, Dorman, NAPA, etc.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
