It is currently Sat Nov 28, 2026 7:35 pm
 Post subject: SpeedO adjustment
PostPosted: Mon Apr 30, 2007 4:31 pm
In my 81 D150 my speed "O" is 5 mph shy of where it should be. I dont have huge tires on (195 15's) and I would like to adjust it so that it is closer to being correct (spot on would be nice).
Any info on adjusting it?
Thanks,
Superman
1981 D150
"The Khaki Machine"
PostPosted: Mon Apr 30, 2007 4:36 pm
They can't be adjusted, per se. If yours is reading consistently low, then a speedometer drive pinion with fewer teeth should be installed.
Users browsing this forum: DuckDuckGo [Bot] and 7 guests
