| in deep https://slantsix.org/forum/viewtopic.php?t=22970 |
| Author: | slantfin [ Mon Apr 30, 2007 4:54 pm ] |
| Post subject: | in deep |
I'm attempting to follow the protocol found at the Jim's Performanced Automotive site, as recommended here. That is the intake centerline method. I started by aligning the dots on the comp timing chain. The point of max lift on cylinder #1 seems to be @ 229 degrees. The cam centerline is supposed to be 105 deg (St-1 carb. Are the dots 124 degrees off, or am I? The duration is 226 @.50. The cam card is, of course, lost in a singularity vortex. Any help? |
| Author: | oldgoat83 [ Mon Apr 30, 2007 5:37 pm ] |
You could try an entanglement trace to find out where it went. |
| Author: | slantfin [ Mon Apr 30, 2007 8:49 pm ] |
| Post subject: | Uhhhhhh |
Beyond the event horizon? D'oh: I just figured out that I was on the exhaust valve rather than the intake. THAT might have something to do with my result. |
| Author: | slantfin [ Mon Apr 30, 2007 9:08 pm ] |
| Post subject: | good call oldgoat83 |
If we let the location of the cam card equal A and the location of the hapless cam installer equal B then the relationship of A to B, in classical terms would most likely be expressed by H(A:B)=H(A)+H(B)- H(A,B) neglecting quantum effects. Or I might have recycled it with the box the cam came in. |
| Author: | Doctor Dodge [ Mon Apr 30, 2007 9:22 pm ] |
Just split the overlap event over TDCEx and call it done. DD |
| Author: | icaneat50eggs [ Mon Apr 30, 2007 9:29 pm ] |
Haha...... Doc and his "voodoo" ways. |
