air cleaner
https://slantsix.org/forum/viewtopic.php?t=22972
Page 1 of 1
Author:  acecafe [ Mon Apr 30, 2007 5:39 pm ]
Post subject:  air cleaner
does anyone make an open element aircleaner to fit the holley 1920? about 10inch diameter?
Author:  BigBlockBanjo [ Mon Apr 30, 2007 5:48 pm ]
Some people aren't crazy about an open-element air cleaner, but they look cool. :)
I have one(brand-new) for sale, but be warned: It's a "home-aid" version! :D
It looks like a hundred bucks on the engine, but it isn't as nice underneath.
PM me with your E-mail, and I'll send you some pics if you want.
BigBlockBanjo
Author:  SlantSixDan [ Mon Apr 30, 2007 7:05 pm ]
Open-element air cleaners look cool (some think) but they don't work as well as the factory units.
Author:  BigBlockBanjo [ Mon Apr 30, 2007 7:08 pm ]
My point is made.....hehe :D
Author:  Slant Cecil [ Mon Apr 30, 2007 8:20 pm ]
The unsilenced air cleaners used in the '60s are the same as an open element cleaner. The ones from '67-'69 were about 10".
Author:  Rug_Trucker [ Mon Apr 30, 2007 8:26 pm ]
WHYZAT?
Author:  kesteb [ Mon Apr 30, 2007 10:26 pm ]
Because Dan said so...
Author:  Jeb [ Tue May 01, 2007 4:37 am ]
Oh boy...
Author:  BigBlockBanjo [ Tue May 01, 2007 6:02 pm ]
WHYZAT?
He's referring to the fact that an open air element does pull in more hot engine air,... it forms a low pressure area over the carb inlet. (Because the air rushing straight through the element goes right over the top of the carb, causing a part-throttle stumble)
It's also harder to hook up a "positive"(?) PVC system....you have to run a small breather on the valve cover. I'm sure I forgot another reason.
Oh yeah, you lose your carb "hot-air" system.
Pro's and Con's. Just make sure you like it, it's your car. It's not like you can't change it right back if you don't like it.
My .02
BBBanjo
