No Va
https://slantsix.org/forum/viewtopic.php?t=22997
Page 1 of 1
Author:  slantfin [ Wed May 02, 2007 8:30 am ]
Post subject:  No Va
A buddy of mine replaced a /6 in his 66 Val w/ AT. The motor started up wonderfully, but when he put it in gear, nothing. I have all clutch cars, so I had nothing to add. Is there somewhere for him to start looking. Maybe the torque converter?
Author:  slantvaliant [ Wed May 02, 2007 10:45 am ]
Check the cheap and easy things first.
Fluid level?
Shift linkages / adjustment?
Author:  Doc [ Wed May 02, 2007 11:00 am ]
Dis-connect one of the AT's coolent lines and start the engine, see if the trans is pumping fluid. (a section of rubber hose and a fluid catch can will reduce the mess)
Did he remove or change converters?
Author:  slantfin [ Wed May 02, 2007 11:09 am ]
Post subject:  Thanks I'll Check
His mom's in the hospital, but I'll have him start with these initial checks. Not sure about converter.
:idea:
Author:  Pierre [ Wed May 02, 2007 11:57 am ]
Hopefully the converter didn't slip out of place.
This may sound stupid, but, he did remember to put those 4 bolts back in between the flexplate and converter, right? EDIT: Ignore this, obviously he did if the car started otherwise the starter would just spin the converter in place.
Leave the car in reverse when checking the fluid lines as I believe thats when the most fluid is being moved.
Author:  Charrlie_S [ Wed May 02, 2007 7:25 pm ]
Is he using a 66 auto trans, with a 68 or later converter? If yes the splines on the trans input shaft are not engaging the splines inside the converter. The 66 trans has a smaller diameter and different spline count then the later converter.
Author:  slantfin [ Thu May 03, 2007 1:43 pm ]
That's possible Charrlie_S, since I think it was a replacement motor with the 66 transmission. If it is pumping fluid, that would be the next thing to find out.
Author:  Doc [ Thu May 03, 2007 4:37 pm ]
If it is the input shaft problem, the trans will pump fluid but the car will not move.
