| holly4 jetting ? https://slantsix.org/forum/viewtopic.php?t=23002 |
| Author: | 6shotvanner [ Wed May 02, 2007 11:30 am ] |
| Post subject: | holly4 jetting ? |
Running a 225 with compcams 260h,clifford intake&headers.A-833 and longlegged reargears.Problem is big dead spot on take off. Tried bigger jets,powervalve,squirtnozel,accpump,powervalve upgrades,still doggy on the get go! What have others done? tks |
| Author: | Mister Twister [ Wed May 02, 2007 12:09 pm ] |
We changed carb and fixed that problem, |
| Author: | 6shotvanner [ Wed May 02, 2007 6:11 pm ] |
| Post subject: | reply to mister twister on holly4 jet ? |
Tks for the quick reply, |
| Author: | terrylittlejohn [ Wed May 02, 2007 7:11 pm ] |
| Post subject: | 390cfm |
hate to add bad new but the first 4bbl i tried was a new390cfm,i did everything that i read about tuning even drilling out the air bleeds for idle and high speed,but the car always stumbled off the line, then i tried a used 600cfm and it was like night and day,it seemed to me i couldnt get the jetting lean enough even with 45#jets(4 steps leaner than new shipped 390 carb) |
| Author: | Wizard [ Wed May 02, 2007 7:38 pm ] |
| Post subject: | transistion is the problem. Air/fuel idle mixture is vital. |
Idle circuit too lean or too rich, causing the transistion bog/strumble. Stick with 390. 600 is BIG for a 225. Cheers, Wizard |
| Author: | Wizard [ Wed May 02, 2007 7:40 pm ] |
| Author: | slantzilla [ Thu May 03, 2007 6:14 am ] |
I run a VS 390 and have never had a stumble off the line except when I had too low a number power valve in it with too big main jets. Right now I have a 10.5 power valve with 52 mains and it is seamless. Is it a primary bog or are the secondaries opening too fast? |
