| Shackle bolt center dimension https://slantsix.org/forum/viewtopic.php?t=23033 |
| Author: | Aggressive Ted [ Fri May 04, 2007 2:13 pm ] |
| Post subject: | Shackle bolt center dimension |
Does anyone happen to know what the stock dimension should be for standard shackles on the rear leaf spring for a Dart? |
| Author: | sandy in BC [ Fri May 04, 2007 2:54 pm ] |
3/8 x 4 1/2 I used 1/2 x 4 1/2 onthe set I just made |
| Author: | Aggressive Ted [ Fri May 04, 2007 3:38 pm ] |
What is the distance between the holes you drilled? Thanks! |
| Author: | RDJ [ Fri May 04, 2007 8:06 pm ] |
| Post subject: | Re: Shackle bolt center dimension |
Quote: Does anyone happen to know what the stock dimension should be for standard shackles on the rear leaf spring for a Dart?
Mine are 4 3/4 total length and 3 1/2 from the center of each bolt.
| Author: | Aggressive Ted [ Fri May 04, 2007 8:09 pm ] |
Thanks much! |
