| Head seepage https://slantsix.org/forum/viewtopic.php?t=23037 |
| Author: | mrhite65 [ Fri May 04, 2007 3:40 pm ] |
| Post subject: | Head seepage |
Noticed that my intake runners have some oil seepage at the head. Its not alot but, there's more at the front one than towords the rear one. I have also had some seepage on the other side. This has gone on since I had the truck (1982 225 auto). Tried different things but, heard that the head might need to be retorqued. Is this true and if so, do I need to put on a new head gasket? |
| Author: | Doc [ Fri May 04, 2007 3:58 pm ] |
It just take some time and a valve cover gasket in order to retorque the head. Warm the engine and test the head bolts to see how tight they are. You will find that they will take a lot of force before the bolt "cracks loose and starts moving / gives you an accurate torque reading. Search the messages for more details. DD |
| Author: | mrhite65 [ Fri May 04, 2007 4:56 pm ] |
When you say crack loose, do you mean to back the bolt out a little then start to torque the bolt forward? |
| Author: | Doc [ Fri May 04, 2007 5:09 pm ] |
Me... I just tighten them more. I used to go in the loosen direction to crack the bolt loose, then tighten but these days I have a better feel for how much overtorque it takes to get the bolt moving, so I just go tighter. DD |
| Author: | mrhite65 [ Fri May 04, 2007 7:23 pm ] |
I have no feel on a torque wrench. Do I torque to specs or more? |
| Author: | Doctor Dodge [ Fri May 04, 2007 8:23 pm ] |
I retorque to 70-75 ftlbs. on cast iron Slants. DD |
| Author: | oldgoat83 [ Sat May 05, 2007 7:40 am ] |
That's exactly what my head was doing. The bolt torques were ok so I pulled the head and had some work done. Just waiting for the weather to clear to get back on it. |
| Author: | mrhite65 [ Sat May 05, 2007 8:31 am ] |
Quote: That's exactly what my head was doing. The bolt torques were ok so I pulled the head and had some work done. Just waiting for the weather to clear to get back on it.
Was the head warped or something else?
| Author: | oldgoat83 [ Sat May 05, 2007 11:10 am ] |
I pulled the head figuring I would replace the gasket. It was filthy from all the oil and 24 years of driving. So I got the head cleaned and resurfaced. I had them do a valve job with new valves. I didn't do a compression test before all this so I don't know if there's still a possibility of bad rings as has been suggested by some. I explained all this to my mechanic to see if he had any ideas. He thought the rings probably weren't the source of the oil. He suggested a PCV system clog. Unfortunately, I'm the only one who's seen the engine outside of pictures that are linked in my sig. |
| Author: | mrhite65 [ Sun May 13, 2007 1:01 pm ] |
Do I loosen all the bolts and then retorque from the center out or loosen and retorque one at a time from the center out? |
| Author: | Doc [ Mon May 14, 2007 9:12 am ] |
Do them one at a time... work from the center, out. DD |
| Author: | mrhite65 [ Fri Jul 13, 2007 12:22 pm ] |
It didn't stop the seepage so I guess need to get a new head gasket. What is recomended? Is Felpro or Rol good? |
