| No A/C in Az https://slantsix.org/forum/viewtopic.php?t=23046 |
| Author: | DusterBuster [ Sat May 05, 2007 1:02 pm ] |
| Post subject: | No A/C in Az |
Hey guys im in bit of a problem...i have searched high and low...not even checkers has it...i need a a/c idler pulley...and i need it bad..lol..all the ones i see dont look anything like the one i have on the duster..cause it has like built in bolt "thingy" and no others have it...plz reply asap..with any info you have..thanks |
| Author: | slantvaliant [ Sat May 05, 2007 3:29 pm ] |
Pics? |
| Author: | SlantSixDan [ Sat May 05, 2007 7:15 pm ] |
You can actually replace the early "built in bolt" type of idler with the later "through bolt" type idler; all you have to do is slightly modify (drill out) the bolt hole in the bracket. Gates 38038 Dayco 89020 AC-Delco 38038 NAPA Belts & Hoses 38038 NAPA Temp Control 209842 ![]() The only "gotchya" you might run into is that this replacement pulley might come without the round shield plates that need to go over the central bearing in order to mount the pulley properly. You may have to find them from a junkyard '76-up car. They are sort of dished washers that contact the ends of the inner race of the bearing, but not the outer race, and space the pulley correctly to line up with the belt. I'm not sure, but a bearing supply house might be able to supply such items. If you get in a real pinch, you could probably improvise with some carefully-stacked regular washers, as long as their outer diameter is small enough not to contact the bearing's outer race. |
| Author: | DusterBuster [ Sun May 06, 2007 12:27 am ] |
thats awesome...thanks for the help..and i do still have that sheild plate so its all good and a bag of cheetos...lol |
| Author: | Romeo Furio [ Sun May 06, 2007 2:04 pm ] |
| Post subject: | pulley |
Yep, do what Dan has posted, Did it last year to mine, shim with washers for correct belt alignment. any auto parts store will have what you need. The pulley maybe larger or smaller.I used a larger one to turn less RPM's Doubt if it matters. |
| Author: | mopardemon71 [ Thu May 10, 2007 8:19 pm ] |
If you need one I have two that I dont need. |
