| Discs & 5 on 4.5 axles for 66 Val wagon https://slantsix.org/forum/viewtopic.php?t=2305 |
| Author: | Gary [ Wed Jun 20, 2001 12:10 pm ] |
| Post subject: | Discs & 5 on 4.5 axles for 66 Val wagon |
I have a '66 Valiant wagon and would like to add disc brakes and custom wheels. The stock wheels have 5 on 4" bolt circles. I would like add 14x7 wheels with 5 on 4.5" bolt circles. Are there axles that I can swap out from another car? If not, how about an entire rear end? What car(s) can I get the discs and axles (or rear end) from and what parts do I need? Thanks, Gary theluketribe@hotmail.com |
| Author: | Doctor Dodge (Doug Dutra) [ Wed Jun 20, 2001 9:58 pm ] |
| Post subject: | Re: Discs & 5 on 4.5 axles for 66 Val wagon |
: I have a '66 Valiant wagon and would like to : add disc brakes and custom wheels. The stock : wheels have 5 on 4" bolt circles. I : would like add 14x7 wheels with 5 on : 4.5" bolt circles. Are there axles that : I can swap out from another car? If not, how : about an entire rear end? What car(s) can I : get the discs and axles (or rear end) from : and what parts do I need? Any big bolt pattern A-body rear end will do the trick. These started in 1973, mostly on V8 cars. Moser also sells "conversion axles" and can also redrill bolt patterns if needed. DD |
| Author: | Brian [ Wed Jun 20, 2001 10:08 pm ] |
Try this site for information... <A HREF="http://www.geocities.com/motorcity/shop ... sk.html</A> At the bottom of each page they have links for other pages like rearends and such... Good luck Quote:
: : Any big bolt pattern A-body rear end will do : the trick. These stared in 1973, mostly on : V8 cars. : : Moser also sells "conversion axles" : and can also redrill bolt patterns if : needed. : DD : DD bduffy@onemain.com |
