| Hyper-Pak Throttle Linkage https://slantsix.org/forum/viewtopic.php?t=2308 |
| Author: | Ken Sharp [ Thu Jun 21, 2001 2:23 pm ] |
| Post subject: | Hyper-Pak Throttle Linkage |
Can someone furnish or direct me to a picture showing the original Hyper-Pak carburetor throttle linkage arrangement? Ken_Sharp@bramco.com |
| Author: | Doctor Dodge (Doug Dutra) [ Sat Jun 23, 2001 10:15 am ] |
| Post subject: | Re: Hyper-Pak Throttle Linkage - Ok |
: Can someone furnish or direct me to a picture : showing the original Hyper-Pak carburetor : throttle linkage arrangement? Ken, I have some stuff on the Hyper Pak linkage but need some time to pull it out, scan it in and post. Do you have a Hyper Pak comming together? What year car / chassis type? Are you OK with using a cable throttle linkage? Keep checking back, I will try to get this done in the up-comming week, I will post a new message once I have it all pulled together. DD |
| Author: | Ken Sharp [ Sat Jun 23, 2001 10:33 pm ] |
| Post subject: | Re: Hyper-Pak Throttle Linkage |
: Can someone furnish or direct me to a picture : showing the original Hyper-Pak carburetor : throttle linkage arrangement? Doug, appreciate the offer. I've a 67 Cuda notchback, 4-sp, 3.55 sure-grip, head milled w/Ford 300 valves, original Hyper-Pak spec Mellings cam and Clifford's (your's!?) intake manifold & Carter 4bbl. Cable throttle is stock on the car, so I'd prefer a cable version. Thanks for the assistance. ksharp@iglou.com |
