| How to adjust cam timing on a /6 ? https://slantsix.org/forum/viewtopic.php?t=2312 |
| Author: | Tim_K [ Sat Jun 23, 2001 9:49 am ] |
| Post subject: | How to adjust cam timing on a /6 ? |
I'm finally building my /6, and have a question on adjusting the valve timing. If an adjustment is needed, should I use an offset key on the crank sprocket, or drill out the cam gear hole and use an offset bushing? I think the offset crank key would be easier if it works. |
| Author: | Doctor Dodge (Doug Dutra) [ Sat Jun 23, 2001 10:50 am ] |
| Post subject: | Re: How to adjust cam timing on a /6 ? |
: I'm finally building my /6, and have a question : on adjusting the valve timing. If an : adjustment is needed, should I use an offset : key on the crank sprocket, or drill out the : cam gear hole and use an offset bushing? I : think the offset crank key would be easier : if it works. Both methodes work fine, truth is that the "off-set bushing(s) in the top cam gear is a little easer to deal with just because the bottom crank gear is a light press-fit, as are the "keys" in the keyway. You need a good puller, more time and "skill" to adjust at the bottom location. This is also true on the "trick" JP "multi-keyed" bottom gear timing set, that bottom gear does not just slip on & off but requires some force to install & remove. ( I heat-up the lower gear to install it with a correct "draw-on" - screw type tool, not with a hammer-Please) Your standard "3-jaw" puller may not have enough room to get behind the bottom gear to remove it. DD |
