It is currently Fri Nov 27, 2026 8:11 pm
PostPosted: Fri May 11, 2007 11:27 pm
64 with 7.25 rear end.
Should I use a replacement gasket, or just goop it up with silicone (don't think they had silicone originally, so is silicone better or worse?)
(just an oil change, and I want to check out the internals while I'm at it)
PostPosted: Sat May 12, 2007 4:57 am
get a gasket at your local parts place. ron
PostPosted: Sat May 12, 2007 8:00 am
Ditto. Always use a gasket when you can. I spent a good couple hour wirewheeling the old goop off my transmission's drain pan and the diff cover, and it was a royal pain. New gaskets on both and they go on easily and seal well. No leaks, no worries.
PostPosted: Sat May 12, 2007 8:18 am
Another vote for "gasket".
PostPosted: Sat May 12, 2007 7:33 pm
SSRN National Champion
Yep Gasket. And doint ever use any goop ie silcone or gasket sealer on a trans pan.If any of it gets smached toward the inside and a piece of silcone breaks loose and goes to the trans vavle body bad news. Thanks Ron Parker :D
Bagels On Juice Im On Boost
PostPosted: Sat May 12, 2007 8:44 pm
How would a piece of silicone get thru the filter? (those with a pan filter, not the earlier remote filters)
Ok, I'll get a gasket, but I was thinking of siliconing it to the cover (letting it dry), then installing it so the gasket won't move on installation
(and I can trim off any goopy pieces before installation tooooo)
PostPosted: Sat May 12, 2007 9:03 pm
Better, faster, and easier: Tie the gasket to the cover plate with lengths of ordinary sewing thread through a couple of the bolt holes. The thread won't interfere with the gasket seal, and can just be left in place.
PostPosted: Sun May 13, 2007 7:38 pm
Doint let a thing like stuff cant get thru the filter to block a opening in the vavle body. Correct parts work better than redneck parts. And I am a professional Red Neck. But I have my race team that includes professional people that have College degres. Thanks Ron Parker :D
PostPosted: Sun May 13, 2007 8:15 pm
For a rear end I would not think twice about using just silicone. I just changed fluid in the 9-1/4" in my R/T and it was siliconed from the factory.
For trans pans Mopar makes a very nice re-useable gasket. :D
PostPosted: Mon May 14, 2007 1:30 pm
I spray the trans pan with HighTack from Permatex and stick the gasket to it. Five seconds later it will stay on even upside down.
The rear I agree with Slantzilla - goup or gasket and goup.
PostPosted: Tue May 15, 2007 5:10 am
Yes we like the high temp spray & gasket, not a big mess when done.Hope this helps Don
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Tue Sep 25, 2007 12:46 pm
So you don't need any goo when replacing a trans pan gasket?
PostPosted: Tue Sep 25, 2007 4:32 pm
That is correct. However the OEM pan gasket for a late model (2001)dodge PU, is a nice improvement, but also recommend the longer pan bolts to go with it.
PostPosted: Tue Sep 25, 2007 4:33 pm
The wifes old Stratus, and the PT, don't have transmission pan gaskets. They are gooped from the factory, and that's what you have to buy and use if you do it yourself.
It's pretty good stuff, too.
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
PostPosted: Wed Oct 24, 2007 3:06 pm
Another vote for gasket on the rear differential cover. ( I just did my 8.25 with stock 3.55 ratio in my 1979 D-100 2wd).
Users browsing this forum: DuckDuckGo [Bot] and 3 guests
