It is currently Sun Nov 29, 2026 11:55 pm
 Post subject: trunk lock fun
PostPosted: Tue May 15, 2007 2:30 pm
So my trunk lock is done for. I ordered another one, but how can I get the cylinder out when I can't get into the trunk? I called the locksmith, but they said they didn't have the parts and wont use any I ordered.
Advice?
'70 Plymouth Duster 225
"A girl can fix stuff too! (sometimes.)"
PostPosted: Tue May 15, 2007 2:41 pm
I went at mine by removing the back seat. There should be a little arm sticking through the latch assembly, grab ahold of it with a pair of pliers, and gently rotate it counterclockwise (looking at it from inside the truk). That'll get it open for ya...
PostPosted: Thu May 17, 2007 5:27 am
And if all you see is a slot, stick a screwdriver in it and turn to the right. That's in case the bar from the cylinder to the latch has fallen out.
If a MedAlert bracelet is the only bling you wear......You might be getting old.
PostPosted: Thu May 17, 2007 11:15 am
Mission accomplished, I managed to break the cylinder with a screwdriver and it opened the latch. Replaced the lock and we are good to go!
This was attempted only after coming to the conclusion that I cant get the backseat off, because my driver seat is welded into the upright position. Good to know.
PostPosted: Thu May 17, 2007 4:34 pm
Weird.
PostPosted: Thu May 17, 2007 11:18 pm
Agreed. I can only assume it broke, and this was the quickest way to fix it.
