| trunk lock fun https://slantsix.org/forum/viewtopic.php?t=23198 |
| Author: | sunshine6 [ Tue May 15, 2007 2:30 pm ] |
| Post subject: | trunk lock fun |
So my trunk lock is done for. I ordered another one, but how can I get the cylinder out when I can't get into the trunk? I called the locksmith, but they said they didn't have the parts and wont use any I ordered. Advice? |
| Author: | sethmcneil [ Tue May 15, 2007 2:41 pm ] |
I went at mine by removing the back seat. There should be a little arm sticking through the latch assembly, grab ahold of it with a pair of pliers, and gently rotate it counterclockwise (looking at it from inside the truk). That'll get it open for ya... |
| Author: | slantedview [ Thu May 17, 2007 5:27 am ] |
And if all you see is a slot, stick a screwdriver in it and turn to the right. That's in case the bar from the cylinder to the latch has fallen out. |
| Author: | sunshine6 [ Thu May 17, 2007 11:15 am ] |
Mission accomplished, I managed to break the cylinder with a screwdriver and it opened the latch. Replaced the lock and we are good to go! This was attempted only after coming to the conclusion that I cant get the backseat off, because my driver seat is welded into the upright position. Good to know. |
| Author: | sethmcneil [ Thu May 17, 2007 4:34 pm ] |
Quote: my driver seat is welded into the upright position.
Weird. |
| Author: | sunshine6 [ Thu May 17, 2007 11:18 pm ] |
Agreed. I can only assume it broke, and this was the quickest way to fix it. |
