| crankshaft https://slantsix.org/forum/viewtopic.php?t=23201 |
| Author: | old-vc [ Tue May 15, 2007 3:28 pm ] |
| Post subject: | crankshaft |
Hi,just pulled the motor out of the car to do a cam swap and on first appearance it seems that there isn't a thread in the end of the crank.If this is so how do you replace the balancer--I'm reluctant to tap it on with a brass hammer for fear of damaging the thrust bearing.Also if there is a thread there what size is it please. Thanks from Al down under |
| Author: | Doc [ Tue May 15, 2007 5:57 pm ] |
Clean and look carefully, all the USA Slants have a 3/4-16 unf thread in the "snout" of the crank. |
| Author: | old-vc [ Tue May 15, 2007 7:19 pm ] |
Thanks Doc,I think all Aussie slants were produced in either the US or Canada so the thread should be there. Once again thanks Al. from down under |
