Head Cold
https://slantsix.org/forum/viewtopic.php?t=23209
Page 1 of 1
Author:  slantfin [ Wed May 16, 2007 8:31 am ]
Post subject:  Head Cold
I've always torqued the cylinder head bolts when hot. If I'm assembling the head, what do people recommend for threadlocker, thread sealer and initial torque (cold)- I'm guessing one should re-torque when hot. Thanks for your input. I looked for a specific article on this forum, but didn't notice any.
Author:  Dart270 [ Wed May 16, 2007 9:43 am ]
I have never torqued the bolts hot, since the new gaskets do not need retorque. No threadlocker is needed, and I usually go higher (75-85 ft-lbs) than the FSM spec. I use oil on the threads, which some people don't like, but I've never had a gasket/bolt problem up to 11:1 and I've done 30-50 head swaps on Slants.
Author:  slantfin [ Wed May 16, 2007 10:23 am ]
Thanks Lou,
Maybe I'm thinking of some of the mainifold studs that need thread sealer because they are open to the water jacket?
Author:  slantzilla [ Wed May 16, 2007 2:15 pm ]
Thanks Lou,
Just the end 2. The rest are blind holes. :lol:
Author:  slantfin [ Wed May 16, 2007 2:21 pm ]
The end near the thermostat?
Author:  dakight [ Wed May 16, 2007 3:46 pm ]
Thanks Lou,
I'll have to check the head I'm working on because I was sure that when I blew out the holes they all went into the water jacket. I'm fairly sure that more than 2 of them did.
Author:  Doc [ Wed May 16, 2007 4:44 pm ]
All the manifold studs go into the water jacket but some heads have so much rust build-up, they don't leak coolent out the hole when the stud is pulled. :shock:
On head torque, I always recheck the head's torque after the first heat cycle. I never use any sealer or thread locker. I do put some anti-seize compound on the bolt threads before installing the bolts.
Author:  dakight [ Wed May 16, 2007 5:24 pm ]
Whew! I was afraid I might have a damaged head. The one for the motor I mean. :shock:
