| a833od into 73 dart- B body long tail questions https://slantsix.org/forum/viewtopic.php?t=23239 |
| Author: | radarsonwheels [ Sat May 19, 2007 3:36 am ] |
| Post subject: | a833od into 73 dart- B body long tail questions |
Howdy Im having a ball messing with my slant, thanks in large part to you all. I finally got my new trans loaded into my house and took stock of what I have. The stuff came out of an 85 d100 truck, and I got everything from zbar to driveshaft (have to shorten that!), including the flywheel and newish borg and beck pressure plate and disc. Now that it has been cleaned up and I know it is all good, I have more questions: 1: Can I install this trans without changing the B-body shifter location (in front of spool mount, towards the front of the tailshaft)? I wonder if a bent shifter could solve the problem if the shifter hits the dash, as long as it misses the bench seat! edit: I re-read the article on here and saw the b body to a body swap. It makes sense that the crossmember with the t-bar sockets would be lined up with the spool mount. My tailshaft is not drilled and tapped on the rear boss, has anybody adapted one of these? 2: Do I need an alignment tool to properly locate the disc when I install the pressure plate? It is my first time doing one of these. 3: My crank is a later model, it fit my late torque converter nub when I installed my motor. I read that you can install a spacer to fit the late model needle bearing, but does anyone know how much to cut off the input shaft? I have parts to mock up, but a second opinion couldn't hurt. Thanks radar |
