| Need vacuum help!!! https://slantsix.org/forum/viewtopic.php?t=23253 |
| Author: | Underdogg [ Sun May 20, 2007 8:44 am ] |
| Post subject: | Need vacuum help!!! |
I just put a SuperSix 225 (year uknown at present)in an '87 P/U and rebuilt the Carter BBD but all vacuum hoses were capped.I need a diagram for it if possible.Engine has wierd pollution stuff at rear of valve cover with a 'drum-like" apparatus and 1"+metal tubes if that helps date the engine. I bought a new '80 truck and new '86 both w/225's and neither had this setup. This one is in an '87 D100 P/U. Can anyone help???[/i] |
| Author: | Rug_Trucker [ Sun May 20, 2007 9:22 am ] |
One at the back and bottom the largest is the PCV. The vac advance for the distributor is mid way up on the carb body pasenger side. |
| Author: | Rug_Trucker [ Sun May 20, 2007 9:23 am ] |
The drum is a vacuum amplifier |
| Author: | mrhite65 [ Sun May 20, 2007 11:24 am ] |
| Author: | Underdogg [ Mon May 21, 2007 4:14 am ] |
Thanks!! What really NEEDS to be hooked up???? |
| Author: | mrhite65 [ Mon May 21, 2007 7:53 am ] |
The only things that NEED to be hooked up to the carb are the vacuum advance, PCV and the fuel hose. |
| Author: | Rug_Trucker [ Mon May 21, 2007 6:08 pm ] |
Quote: The only things that NEED to be hooked up to the carb are the vacuum advance, PCV and the fuel hose.
Don't run the vac advance to anything but the distributor. Bypass the little gizmatchie on the air cleaner that says "carb" and "distributor" on it. Go direct! |
| Author: | Underdogg [ Tue May 22, 2007 9:59 am ] |
| Post subject: | Vacuum adv |
There is no Vac advance on this distributor!! Just cap it?? |
| Author: | mrhite65 [ Tue May 22, 2007 1:24 pm ] |
Yes, cap it off. I didn't realize you still had the computer. |
