It is currently Thu May 14, 2026 4:31 am
 Post subject: Axle Bearing Question
PostPosted: Fri May 25, 2007 1:37 pm
I am installing new bearings in an 8 1/4 today... It looks to me that they(the bearings) are lubed by the gear oil that fills the entire housing, is that accurate?
If that is true, is it a necessity to pack the bearings with grease? or will the oil act as a salivant and wash the grease away anyway?
PostPosted: Fri May 25, 2007 6:40 pm
I don't know if the rear end oil makes it to the bearings or not.......
But if it does, I'd pack them in a light grease so they're lubed until the rear-end oil gets to the bearings.............. (I'd probably just use white lithium)
PostPosted: Sat May 26, 2007 10:12 am
Yes the diff fluid lubes the axle bearings.
Excuse me, does this smell like chloroform to you?
PostPosted: Sat May 26, 2007 11:54 am
salivant
I meant solvent...
Users browsing this forum: Amazon [Bot] and 3 guests
