| Got my Aussie gaskets https://slantsix.org/forum/viewtopic.php?t=23262 |
| Author: | Jopapa [ Sun May 20, 2007 5:22 pm ] |
| Post subject: | Got my Aussie gaskets |
My new manifold gaskets came a couple days ago and hopefully the week after Memorial Day I'll be able to get them installed. I'm planning on doing this right the first time. So far I've got: Manifold/head gasket Intake/exhaust gasket New exhaust downpipe gasket New carb gasket (the current one leaks, so what better time to swap it out) New head/manifold studs and nuts High temp thread sealer (the 3M stuff) Edit: Loctite 592, not 3M Anything else I might need to make sure I do this right? What method should I use to properly torque the new studs when I install them into the head? Any other tips or advice, as always, is more than welcome. |
| Author: | HyperValiant [ Sun May 20, 2007 8:10 pm ] |
You will like the Aussie gaskets,I just installed them on my Daughters 72 Valiant and they worked beautifully. HyperValiant |
| Author: | Jopapa [ Sun May 20, 2007 9:49 pm ] |
Quote: You will like the Aussie gaskets,I just installed them on my Daughters 72 Valiant and they worked beautifully.
Outstanding. I plan to install them dry, after a good amount of surface cleanup and cleaning the carbon buildup from the EGR out of the intake manifold (and plugging the hole as well if I can find the right size plug).HyperValiant Still though, how tightly do I want to install the studs into the head? Just finger tight with the high temp thread locker, or is there another way to properly do it? |
| Author: | SlantSixDan [ Mon May 21, 2007 8:14 am ] |
Clean the studs and the stud holes in the head, make sure whatever you used (brake cleaner?) to clean the stud holes is fully evaporated out of the holes, apply the threadlocker per instructions, then run-in each stud until it's tight. Easiest way is to put two nuts on the stud, use the front one to tighten the stud, use two wrenches to remove the front nut, let the threadlocker set up, then remove the rear nut. |
