| Diff. ingition curves for different combustion chambers? https://slantsix.org/forum/viewtopic.php?t=23271 |
| Author: | Wizard [ Mon May 21, 2007 10:55 am ] |
| Post subject: | Diff. ingition curves for different combustion chambers? |
Tried google and could not get what I wanted to know how much ingition timing is for slow burn aka bathtub combustion chamber head (287) style compared to fast burn heads (782). All I know is that bathtub burns slow and need so much timing compared to fastburn combustion chamber which need less timing. But how much? Reason I ask about this is pervious owner had original bathtub head replaced on this mopar 2.2L with fastburn type but didn't use correct ingition timing curve for it so is there a problem with this? Less performance? etc? I was thinking of pulling base timing back few degrees to go by till I have megasquirt installed. Cheers, Wizard |
| Author: | Matt Cramer [ Tue May 22, 2007 5:35 pm ] |
If it isn't pinging, things can probably wait until you go to a fully adjustable ECU and get it dyno tuned. |
