| Manifold conversion for '73 Powerwagon https://slantsix.org/forum/viewtopic.php?t=23275 |
| Author: | 8track225 [ Mon May 21, 2007 1:28 pm ] |
| Post subject: | Manifold conversion for '73 Powerwagon |
I just removed the old I bbl set up from my slant and when I attempted to put on the 2bbl setup the gasket would not line up. The end hole is the problem. I tried to bolt it on and then pry the exhaust against the intake runner but the bolt will only start a bit and then start to strip out.There is a big difference between each side. After reading the archives, I was thinking that a set of Dutra Duals may be the ticket. My truck does have a clutch cross shaft, low starter and it is 4WD. If anybody has any powerwagon that did this conversion or any other info, please let me know. I sent Doug an email but I'm not sure it was the correct address. Thanks and have a great day to ya all!! Kevin in PA [/img] |
| Author: | Doc [ Mon May 21, 2007 2:33 pm ] |
It sounds like your exhaust manifold is warpped which is not uncommon. I will have to check my email and get you some info on Dutra Duals. There are no fit problems with the dual cast iron manifolds in your truck. DD |
