| 2bbl air cleaner base needed https://slantsix.org/forum/viewtopic.php?t=2328 |
| Author: | Daniel J. Stern [ Wed Jun 27, 2001 11:54 am ] |
| Post subject: | 2bbl air cleaner base needed |
I need a good "small" (e.g. Carter BBD/smallblock) 2bbl air cleaner baseplate. The space constraints in the '62 A-body engine compartment mean in order to run my 2bbl, I need to cut the carb hole out of a 2bbl baseplate and "paste" (weld) it onto a 1bbl baseplate so I can use the 1bbl air cleaner assembly that clears the engine bay. Doug or anyone? DS redbear@vrx.net |
| Author: | Wesley A. Moeller [ Thu Jun 28, 2001 11:16 am ] |
| Post subject: | Re: 2bbl air cleaner base needed |
: I need a good "small" (e.g. Carter : BBD/smallblock) 2bbl air cleaner baseplate. : The space constraints in the '62 A-body : engine compartment mean in order to run my : 2bbl, I need to cut the carb hole out of a : 2bbl baseplate and "paste" (weld) : it onto a 1bbl baseplate so I can use the : 1bbl air cleaner assembly that clears the : engine bay. Doug or anyone? Dan, Are you still looking for one of these? Let me know, if you just need a 2bbl air cleaner base, I'm sure I can find one in my garage. Let me know, Wes '78 Volare <A HREF="mailto:wes.moeller@compaq.com">wes.moeller@compaq.com</A> : : DS wes.moeller@compaq.com |
