It is currently Sun Nov 22, 2026 1:16 pm
PostPosted: Mon May 21, 2007 10:55 am
Tried google and could not get what I wanted to know how much ingition timing is for slow burn aka bathtub combustion chamber head (287) style compared to fast burn heads (782).
All I know is that bathtub burns slow and need so much timing compared to fastburn combustion chamber which need less timing. But how much?
Reason I ask about this is pervious owner had original bathtub head replaced on this mopar 2.2L with fastburn type but didn't use correct ingition timing curve for it so is there a problem with this? Less performance? etc?
I was thinking of pulling base timing back few degrees to go by till I have
megasquirt installed.
Cheers, Wizard
PostPosted: Tue May 22, 2007 5:35 pm
If it isn't pinging, things can probably wait until you go to a fully adjustable ECU and get it dyno tuned.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
